Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
New Diesel
Old Jul 26, 2008 | 03:06 PM
94cummins12v's Avatar
Default New Diesel
well guys i can officially say my diesel blend is working. ive been running "Brandons Signiture alternate diesel" in my truck for a little over a year and it seems to be working well with the same dyno ratings as ulsd in my 94 cummins 12v. its very easy to make and its only about $0.60 a gallon
woops almost forgot guess i should tell you what i used. i have to blends a a winter and a summer blend. my winter blend fills a 55 gallon drum it consists of 10 gallons ULSD, 1qt Lucas fuel addative, 1 gallon of kerosene and 44 gallons of old roten, smelly, varnished over gasoline that has been sitting for years. and the summer blend is 5 gallons ULSD, 1 Qt Lucas, and 50 gallons of the rotten gas. let me know what everyone thinks
Last edited by 94cummins12v; Jul 26, 2008 at 03:07 PM. Reason: Automerged Doublepost
Old Jul 26, 2008 | 07:28 PM
2500HeavyDuty's Avatar
no rotten eggs?
Old Jul 26, 2008 | 11:28 PM
nope just rotten gas dyno results only differ 1 or 2 numbers so i know it works excelent in my truck i wouldnt try it in any electronically fuel injected system since the pump isnt lubed with engine oil like my 12v is with the p7100 mechanical pump
Old Jul 26, 2008 | 11:34 PM
yeah, i wouldnt try it on my fancy common rail injection system
Old Jul 27, 2008 | 11:20 AM
jdugie123's Avatar
ya i would be more worried about destination even if it is old gas. but i am glad you have it working we need to do anything to get away from dino diesel i think
Old Jul 28, 2008 | 12:01 AM
i wouldnt try it in anything new, but its worked out great for my truck at first i was affraid of it started off with 30 gallons of ulsd and began to use less every time until i started noticing a change then i put more diesel in it and this is the numbers ive stuck with now about 5 of my buddies run it one wich is a 99 24v and i have to add more lukas and a qt of 2 stoke oil to get it to lube the pump right
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
May 28, 2015 11:45 PM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
