07 Duramax Help
Old Jul 15, 2008 | 04:03 PM
wilsonbaird's Avatar
Red face 07 Duramax Help
Hi. I am having a problem with 6.6 2007 Sierra Classic, there is a hard code P0107. I have installed EGR stick from PPE and also electronic boost control. The dealer tried to help, but after 100 feet truck goes back to limp mode. He told me to get truck back stock and he will fix, but before I would like to fix it with the upgrades... if there is anybody knowledgeable I will appreciate any help. Thanks
Old Jul 15, 2008 | 05:21 PM
Welcome...I cant help you but Im moving this for better exposure.
Old Jul 15, 2008 | 05:46 PM
Johnny Cetane's Avatar
It would be a huge help if you would go into your User controls and fully fill out a signature for us.
Let me try and research this and see what I can find. It appears it would indicate an overboost condidtion.
Old Jul 15, 2008 | 05:53 PM
2500HeavyDuty's Avatar
did you block you egr too when u fingerd it?
Old Jul 15, 2008 | 06:01 PM
Do you have a boost gauge? What are your readings? I've read that you can set this code with a boost controller if you go above 28psi.
Old Jul 15, 2008 | 06:11 PM
jdugie123's Avatar
i would go back and make sure all your connection are good you would be surprise how a connector that looks good may not be i had one wire loose once and my truck wouldn't even start. start at the MAP sensor that is what the code is from
Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage, this is what the code is
Old Jul 18, 2008 | 07:41 PM
DB Admin's Avatar
Banned
Any Updates ?
Old Jul 31, 2008 | 08:47 PM
Uncle Bubba's Avatar
If there is any new info or more questions on this thread, as the thread starter you can use the thread tools to re-open it at any time. Hope it all worked out.
jt19
Aug 20, 2015 12:18 AM
Jul 28, 2015 12:40 PM
jt19
Jul 13, 2015 03:06 PM
duramaxtuner
Dec 10, 2014 01:24 PM
Dec 3, 2014 08:10 AM
