Cat C7 ----- No Fuel!
Old Jul 13, 2008 | 09:31 AM
Bucket Truck's Avatar
Default Cat C7 ----- No Fuel!
We had a trouble call this morning and our pole truck operator was parked on the side of the rode. Well all the fuel drained to the passenger tank. They winched it onto level ground and pumped some off road into it. Still wouldn't crank so they cracked an injector, which I told they not to do, and now they are covered in oil! HA-HA! But how in the world do you prime a C7 without a primer pump?
Old Jul 13, 2008 | 09:42 AM
wildbill's Avatar
Try and refill the fuel filters if they are empty. Other than that, dang good question!
Old Jul 13, 2008 | 09:51 AM
Yeah i figured that one. They gave up on it. And I was soaking wet so I came on home. Thanks for the quick response Willbill!
Any other takers??? Would like some pointers before I head over to check it out.
Old Jul 13, 2008 | 11:29 AM
mikmaze's Avatar
crack the filter loose, and then stuff a rag and a blow off tip on the air line into the tank with fuel, let the air pressure push the fuel through the lines to the filter when it starts leakin out, tighten the filter and then try to start the beast while holding the pressure in the tank semi sealed with a rag.
Old Jul 13, 2008 | 11:31 AM
wildbill's Avatar
Forgot about that trick.
Old Jul 13, 2008 | 11:38 AM
mikmaze's Avatar
it usually works great, I got so tired of the kids that worked for me running the tractor out of fuel that I put a tire valve right in the fuel cap...... toss in a few gallons, hook on the air line, and crank.............. on my way in a few seconds.
Old Jul 14, 2008 | 10:57 AM
Thanks for the help guys!
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
moneypitk5
Feb 12, 2015 11:01 AM
RLLBZ
Chevy/GMC Duramax 01-04 LB7
Jan 27, 2015 03:05 PM
tbreddiesel
Thoroughbred Diesel
Oct 29, 2014 02:40 PM
