12v No Start
Old Jul 12, 2008 | 11:03 AM
Red_Rattler's Avatar
High Tech Redneck
Default 12v No Start
I'm goin to look at a 96 12v thats forsale but as the title says it won't start. It turns over i believe? Didn't get all the info on it yet. But I know it was running and one day it wouldn't. So I was wondering what some of the simple things there are that won't let a 12v start. I remember something about a fuel shutoff solenoid or something like that? 12v are new to me so as much detail as possible would be great! Thanks
Old Jul 12, 2008 | 11:25 AM
wildbill's Avatar
If there isn't juice, check all the fuses. If there is power, it's either the fuel cutoff solenoid or the fuel pump.
xzaq103's Avatar
FormerVendor
The shutoff solenoid is hanging off the pump on the drivers side. Turn the key to run position and pull it up by hand. Its a very common problem. If its a stick you could wire it up and kill it by putting it in 5th and dropping the clutch. Don't do it too often but you can do it till you get a replacement. Other things it could be... Maybe an overflow valve loosing prime etc but if i had to bet i would go with the shutoff solenoid
Old Jul 12, 2008 | 12:35 PM
Could be shutdown solenoid (you can often R&R that for free), bad batteries, or could be fuel related (overflow valve, lift pump - unlikely, air getting in the system somewhere, clogged prefilter etc.).
Follow the above advice first and see how it goes.
Old Jul 15, 2008 | 05:33 PM
Did you get a chance to look at this?
Old Jul 15, 2008 | 05:47 PM
High Tech Redneck
Any day now..... Dudes up north at the moment, he'd said he'd give me a call when he gets back.... Trucks nothin special 2wd long box ext cab lil rusty but its got the motor...... Plus I found out its a 97 But he wouldn't give me a price on it thou till he gets back.... Kinda weird So if I pull up on the fuel shut off and hold it there the truck should start is what your saying?
Old Jul 15, 2008 | 06:20 PM
Yes. Put your hand on it and have him turn the key. You should feel it pull up. If it does try to pull it up some more, if it doesnt pull up, pull it up manually.
Old Jul 18, 2008 | 07:42 PM
DB Admin's Avatar
Banned
Any Updates ?
Old Jul 31, 2008 | 08:48 PM
Uncle Bubba's Avatar
If there is any new info or more questions on this thread, as the thread starter you can use the thread tools to re-open it at any time. Hope it all worked out.
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
