Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
Low Sulfur Diesel?
Old Jul 7, 2008 | 12:39 AM
W150CTDproject's Avatar
Default Low Sulfur Diesel?
I heard that the low sulfur diesel is extremely bad for your diesel engine. One of my buddies said that a quart of ATF helps when he's running low sulfur in his 94 Dodge 12 valve. Crazy? i dont kno, what do u guys think?
Old Jul 7, 2008 | 01:12 AM
2500HeavyDuty's Avatar
crazy old timer, u can use 2 stroke oil or one of the major diesel fuel additives.
and the LSD is harsh on the old trucks.
Old Jul 7, 2008 | 06:08 AM
wildbill's Avatar
Old Jul 7, 2008 | 06:16 AM
U heard me, maaaaaan
Old Jul 7, 2008 | 08:45 AM
2001shrtbedcummins's Avatar
no LSD is good on older trucks ULSD is bad...kills seals in some of the pumps.
LSD is bad for new trucks...
Old Jul 7, 2008 | 09:11 AM
Your buddy is right in the fact that ULSD has had most of the lubricating properties stripped out of it....but needs to do a little research before he adds ATF to his tank. This was an old mechanic/truckers trick from way back in the day. But, the formulation of ATF has changed and it now contains friction modifiers that will quickly wear the very close tolerances of the modern day an injector pump. Plus, ATF is not designed to be burned.
Using a good fuel additive such as Howes Lubricator, Stanadyne, or Power Service is much better for an engine than ATF. A lot of people (including me) also use TCW-3 2 stroke oil for added lubrication, as the 2 stroke leaves very little ash/crap after its burned.
Old Jul 7, 2008 | 09:55 AM
01quadcab's Avatar
Old Jul 7, 2008 | 04:49 PM
u know what i mean, they still sell LSD?
Old Jul 7, 2008 | 08:24 PM
slowtowpig's Avatar
yea, its gold when you find it, ahhhh 500 ppm, those where the days.....
Old Jul 8, 2008 | 12:00 AM
Originally Posted by Dr. Evil
Your buddy is right in the fact that ULSD has had most of the lubricating properties stripped out of it....but needs to do a little research before he adds ATF to his tank. This was an old mechanic/truckers trick from way back in the day. But, the formulation of ATF has changed and it now contains friction modifiers that will quickly wear the very close tolerances of the modern day an injector pump. Plus, ATF is not designed to be burned..
He already does put ATF in it, ill let him kno asap. He also uses Klots 2 stroke dirtbike oil since we're all motocrossers and snowmobilers. adds a nice touch of race smell to the exhaust actually.
