Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
04.5 duramax tranny temp gauge
Old Jul 17, 2025 | 08:38 AM
Jimmy29's Avatar
Default 04.5 duramax tranny temp gauge
Hi, any help would be great my duramax temp gauge works like it should when started for the first time in the day but when I try to leave work for lunch after about 5 hours of it sitting the gauge will peg at 300 or stay at zero no mater how much I drive but if I let it run for awhile when it’s at 300 it will drop to zero and stay there. I’ve used i temp gun to see what the tranny pan was at while the gauge says 300 and its cold I’ve replaced the internal wiring harness and the transmission temp sensor, new fluid and filters. But during the winter time the gauge reads perfect. My guess would be a stepper motor or wiring problem but it doesn’t add up why it would work fine in the cold. I can tell the TCM was replaced from whoever had it before me. I will get codes everyonce in awhile but they go aways after driving for alittle while. The codes I get are P0700 transmission control system (MIL request) p0711Transmission Fluid Temperature
Sensor ACircuit Range/Pertormance and P0712 Transmission FluidTemperature Sensor A Circuit Low Input. Thank you in advance for your help
99stackedpowerstroke
Feb 7, 2015 10:58 AM
ace
Jan 24, 2012 06:56 PM
Smoke4Broke
May 3, 2010 08:28 PM
over worked
Apr 6, 2010 07:07 PM
Lostnwalmart
9
Jul 31, 2008 08:46 PM
