2004 international 4300 no start
Old Nov 29, 2024 | 12:01 PM
Plumkraxy9's Avatar
Default 2004 international 4300 no start
Truck ran fine. Front timing cover cracked leaking oil. We replaced it. Removing gears and put front of engine back together. Now we have a no start. Runs on ether. We have 150 RPM. Ranking good motor oil pressure. New cam sensor shimmed. Dead headed hpop had only 250 psi. Put a hpop of a running truck still only have 250 psi. Truck will not start. Have 12 volts and power to irp and it has a ground when cranking. Possible something wrong with timing? No laptop available but don't have any codes with code reader scanner.
irozchris
Mar 14, 2015 11:16 PM
Tyler_302
Oct 22, 2014 07:08 PM
JPT99
Aug 17, 2014 09:16 AM
ron2001
Apr 3, 2013 12:26 PM
nick17989
9
Jun 10, 2011 10:17 PM
