2001 Cummins alternator voltage gauge reading at 8
Old Jan 7, 2024 | 11:01 PM
Ez-g's Avatar
Default 2001 Cummins alternator voltage gauge reading at 8
I have a 2001 cummins truck. I started the truck and let run for 10 minutes. Then turned on the lights and started driving. About 5 seconds of driving and the voltage gauge went all the way down and check gauges light came on. Turned off and back on and it was reading at about 10 volts on gauge. Then after about 2 minutes it went all the way down and check gauges light came on again. Is it the ECM?
Old Sep 12, 2024 | 11:49 AM
JohnC12's Avatar
It sounds more like an alternator or battery issue rather than the ECM. When the voltage gauge drops like that, it usually indicates that the alternator isn’t charging the battery properly or the battery is failing. I'd recommend testing the alternator output and checking the battery connections first. Corroded terminals or a weak battery can also cause voltage drops. If those check out, then you might want to look into the ECM, but I’d start with the basics!
Timothy Fleenor
Jul 22, 2017 07:15 PM
FlyingDutcman
Jan 15, 2014 11:03 PM
boquet6
Nov 21, 2013 01:03 PM
J-Pipes
Jun 2, 2010 11:19 PM
CumminsCrazed
12
Dec 19, 2009 02:08 PM
