98 Dodge 12V Fuel Leak
Old Jun 30, 2008 | 12:51 PM
supersportjim's Avatar
Default 98 Dodge 12V Fuel Leak
yesterday i went to go tow my fathers boat and i noticed a decent size puddle of fuel under my truck. it seems to be leaking over by the fuel filter maybe a little more behind that. i did change my fuel filter last week. i did tighten everything up. i checked the drain valve and that is closed. i haven't really had time to look yet. hopefully tomorrow i can. i did see this post. maybe a similar problem. i dunno how similar the 12v and the 24v are tho.
https://www.dieselbombers.com/diesel...king-fuel.html
any help or ideas would be greatly appreciated. thanks!!
Old Jun 30, 2008 | 01:03 PM
DB Admin's Avatar
Banned
Re tighten your injection lines !
Old Jun 30, 2008 | 01:08 PM
Jim are you sure you got the o-rings/gasket in right?:
http://www.dodgeram.org/tech/dsl/fil...uel_filter.htm
Old Jun 30, 2008 | 02:20 PM
MotorOilMcCall's Avatar
Thats what I'll bet on, those big o-rings can be a PITA to get back on right. I've gone through more than a few in my 97.
Old Jun 30, 2008 | 02:30 PM
which ones and where exactly are they? thanks
Ram 97+ Diesel Fuel Filter Change
im pretty sure i have them in right. i will first check the injector lines. then inspect and replace if necessary.
Last edited by supersportjim; Jun 30, 2008 at 02:30 PM. Reason: Automerged Doublepost
Old Jun 30, 2008 | 03:51 PM
DB Admin's Avatar
Banned
The lines that run from your pump tighten each one at the pump and at the injectors
Old Jun 30, 2008 | 05:08 PM
gotcha thank you
Old Jul 3, 2008 | 04:22 PM
well i found where its leaking from. it looks like it will be fun to replace. im guessing it is the fuel supply line?
when i run the truck it squirts out right before the hose clamp. its a crappy cell phone pic.
and it seems like it may be a rubber line i cant quite tell. im going to try and rip into it more tomorrow.
oh and my headlights only work on high beam. new bulbs i checked the fuse. any ideas? thanks!
Last edited by supersportjim; Jul 3, 2008 at 04:22 PM. Reason: Automerged Doublepost
Old Jul 4, 2008 | 12:11 AM
gone ropin's Avatar
had one like it go out on my 96, its a pre formed hose, luckily my local cummins dealer had one on the shelf, i now carry a spare one in the glove box, although you can use a long pice of fuel line for a temporary repair untill you get the rite part,
Old Jul 4, 2008 | 12:15 AM
what exactly is it called? any tips while replacing it? any chance you could snap a pic of your spare for me? thanks
