Diesel Bombers Sponsors These Great Manufactures, Distributors and Vendors Support Our Forum
Head off-road with new Skyjacker Softride Coil Spring Suspension Lift Kit
Old Dec 1, 2021 | 08:39 AM
carid's Avatar
FormerVendor
Default Head off-road with new Skyjacker Softride Coil Spring Suspension Lift Kit
Raise your Dodge Ram above the masses and customize its looks and performance with the new Softride Coil Spring Front and Rear Suspension Lift Kit by Skyjacker. This kit allows you to receive a 4-inch lift, increase your rig's ground clearance, maintain the high level of the original ride quality while also providing key features needed for off-road durability.
If the original ride quality, long-lasting comfort, and aggressive look are your main goals, this kit is for you. Along with its front and rear ride balanced design, you get an unmatched performance. Each kit comes with all the components you'll need, including front and rear coil springs, front track bar brackets, front polyurethane bump stops, sway bar brackets, radius arm brackets, and more.
Cross the roughest terrains with confidence after installing the new Softride Lift Kit by Skyjacker.
Skyjacker® - 4" Softride™ Coil Spring Front and Rear Suspension Lift Kit
https://www.carid.com/skyjacker/4-so...r19451k-m.html
Specifications:
  • With Front Coil Springs
  • With Rear Coil Springs
  • With Front and Rear M95 Monotube Shocks
  • Max Tire Size: 37"x12.5"
  • Wheels and tires recommended parameters: 37"x12.5" with 5.625" Backspacing - trimming may be required
Includes:
  • Front Coil Springs
  • Front Track Bar Bracket
  • Front Polyurethane Bump Stops
  • Front Sway Bar Brackets
  • Radius Arm Brackets
  • Rear Coil Springs
  • Rear Bump Stop Brackets
  • Rear Sway Bar End Links
  • Front and Rear M95 Monotube Shocks
bigred91
13
Apr 26, 2012 07:37 AM
ztk7220
Tire, Wheel & Suspension
Oct 28, 2010 01:18 PM
jimrd
Feb 19, 2010 10:11 AM
Uncle Bubba
Price Quote - Request A Price
May 14, 2008 12:35 AM
Buckshotmckee
5.9L CR Performance
14
Jun 5, 2007 12:09 AM
