Audio Equipment/Electrical Discussions Based on Automotive Stereo Equipment Such As Amps , Head Units & Speakers Including Installation and System Set Up Information. Electrical or wiring issues on anything that requires wiring.
Is My Radio Dead Out Of Box
Old Jun 26, 2008 | 08:25 PM
jdugie123's Avatar
Default Is My Radio Dead Out Of Box
ok this is what i am thinking is going on my new alpine W505 is dead i have all the wires hooked up and when i plug it in to make sure it works i get nothing once i turn the key on i have tested with a light tester the battery constant and it is good also the red lead wire to make sure it is good and it is. then i thought well maybe my ground is bad but i tested that and it is a good ground so is there anything i could be missing i really need this radio for a trip i am taking on tuesday any help would be great. the only wire i didn't touch was the orange wire coming out of the Pac harness do i need to connect that to a constant or just leave it alone the only reason i ask is because there is no were to connect that wire on the alpine harness
Old Jun 26, 2008 | 08:28 PM
wildbill's Avatar
Could be a blown fuse. Should be next to where the harness plugs in.
Old Jun 26, 2008 | 08:29 PM
Benjamin's Avatar
Bombardier
orange wire is for night dimmer when you turn the headlights on. check power to the red and yellow wire using the ground from the radio to test it. also run another ground to the chassis as a test just to make sure.....
Old Jun 26, 2008 | 08:30 PM
Benjamin's Avatar
Bombardier
also was the antenna plugged in?
Old Jun 26, 2008 | 09:01 PM
jdugie123's Avatar
yes the antenna was plugged in. I have tried the ground all the wires that should be hot are hot ( tested with a light tester ) the first thing i thought was a bad ground so i took a piece of wire that i had laying around and put it into the slot from the radio harness and hooked the tester to that and still same results the battery wire is hot and the red switched is hot with the key in the on position
Old Jun 26, 2008 | 09:14 PM
Benjamin's Avatar
Bombardier
this may sound dumb but have you hit the power / source button. i know alpines back in the day would have to be initially powered on manually by the power button....
Old Jun 26, 2008 | 09:19 PM
jdugie123's Avatar
ya i tried that. this really sucks i am leaving in a few days and now i will have to put the stupid factory one in if i can't get it fixed
Old Jun 26, 2008 | 09:43 PM
Benjamin's Avatar
Bombardier
did you try pressing and holding the power button? also try pressing 1 or 6 on the presets.... i know it's not manly but did you read the instructions..... i've had some kick my before....
Old Jun 27, 2008 | 09:22 AM
jdugie123's Avatar
its a touch screen so i can't try the presets i got intouch with the seller and he is going to forward my email to the tech support and hopefully they can help me resolve this i think it is just a wire hooked up wrong or maybe a switch i need to move i can't find anything is the instructions about this
anyone that has installed this unit what wire must be hooked up to make the unit turn on i have power to the battery constant and the red lead wire i have checked the ground to make sure it is good. so again what all wire do i need to have hooked up to get the radio to turn on it is the alpine IVA W505
Old Jun 27, 2008 | 10:45 AM
wildbill's Avatar
Check the fuse on the back of the unit?
