6.2 diesel 18:1 compression pistons?
Old Sep 15, 2021 | 07:22 PM
Chuckanut's Avatar
Default 6.2 diesel 18:1 compression pistons?
Heys guys, I have a 6.2 660 engine and I have a friend that can make me 18 to 1 compression pistons for it. I was also going to do splayed main caps, main studs, head studs, fluidamper, and a HX35/40 hybrid turbo, I am lowering the compression because the engine already has 21 to 1 compression and I don’t like the thought of putting a turbo on that because even with such a little boost you can break things. And I was told if you lower the compression it lowers the harmonics in the engine and you can increase boost pressure slightly. My question is are 18 to 1 compression pistons worth it? I hear they work well in 6.5 diesel’s (with a turned up mechanical injection pump), what about a 6.2? I’ve been on the edge of I should do this build, it’ll be fun to see what the outcome is and no this is a waste of time building a 6.2 even though I’ve seen pretty decent numbers from a 6.2 with a turbo.
thanks guys.
knklbstr
Feb 17, 2013 04:21 PM
2MuchJunk
6.2L & 6.5L Performance
12
Jan 30, 2013 03:14 AM
rollincoal69
Sep 28, 2011 01:35 PM
Smarty=Cummins
5.9L 24V Performance
9
Feb 19, 2011 10:39 PM
86k5
10
Nov 28, 2009 09:52 PM
