Fass pump on 8.3 ISC dutch star
Old Aug 22, 2021 | 07:28 PM
Cheeko's Avatar
Default Fass pump on 8.3 ISC dutch star
I'll start by saying that I'm new to all this.
I have an 8.3 ISC Cummins with a high psi CAPS fuel pump. There is a priming fuel pump that turns on when the key is turned to the ON position, and it only runs for 30-60 seconds and turns off. The mechanical side of the caps fuel pump is then primed and sucks fuel from the tank.
I had problems with it starting, could hear gurgling sounds from the priming pump as if was grabbing air. Found three little mounting bolts on it and got about two complete turns on each bolt. The gurgling air sound disappeared and it started.
Preemptively, I decided to try and save the CAPS fuel pump by installing a fass system. The fass pump provides 16psi of fuel to the caps at all times. The model of fass I got has a return line, always cleaning the fuel of air and particulates. Instead of running the return line all the way to the tank, I tapped into the engine return line. It started and ran great, until I pressed the throttle, then it died. All the injectors are getting fuel, the air is bled out. I loosened the banjo fitting from the engine return line, and its shooting fuel out of it when the engine isn't running. Would that psi prevent the engine from running? I thought there was a check valve installed, but even then, if the return line is pressurized from the new fass return, would that pressure be my problem?
For troubleshooting I was going to disconnect the return of the fass pump and stick it in a five gallon diesel can, then try and start it with no pressure on the engine return line. Does anybody have some advice for a newbie here? Am I on the right track? I did a little research before installing, and a mechanic who installs fass systems said I could plumb into the return line like that. He also said he mostly only installs the model of fass that doesn't have a tank return.
Thanks for any advice
Old Aug 22, 2021 | 07:32 PM
Cheeko's Avatar
Well, so I put the return line from the fass pump in a five gallon can while trying to turn over the engine. Still nothing. Strange this was that with just the fass pump running, no engine cranking, crack the injectors and had fuel flowing. Does this mean there's a bad check on the engine return? Would that be the cause of no starts now? Why am I getting fuel out of the injectors when the engine isn't turning over? The caps fuel pump would be returning all fuel from the fass pump since the engine isn't turning over, that line ties into the engine return back to tank. ...
Old Aug 26, 2021 | 07:19 AM
Cheeko's Avatar
Not much action in here. Is this posted in the wrong place? Can anybody see this?
Cheeko
Aug 21, 2021 06:06 PM
CL-14
Oct 10, 2014 01:37 PM
ebbtide357
Sep 26, 2011 06:45 PM
strokeorcroak
94-98 7.3L Performance
Sep 20, 2011 11:31 AM
STUMPMAN
27
Dec 13, 2009 10:35 AM
