6.7 won't stay running
Old Jun 19, 2021 | 06:25 PM
Cligger's Avatar
Question 6.7 won't stay running
Got a 2007.5 6.7 Cummy, decided to put in the dpf delete, the egr delete, throttle valve delete, and throw in a Fass lift pump. Got it all installed, now it fires up, run a few heartbeats, then dies.Hooked a gauge up to the fuel line just before the injector pump, shows 20-21 lbs when pump is running. after start, pumps holds steady at 20-21, then dies.The longest I've gotten out of it running is about 1 minute, I've bled the system 20 times, it was showing a P007d code, and a P0107. Erased those codes, now I get a P2267 code, whitch I can't even find in any code chart wtf am I doing wrong?
Old Jun 22, 2021 | 11:25 PM
gunman41mag's Avatar
Moderator
https://www.obd-codes.com/p2267
Old Jun 22, 2021 | 11:28 PM
Moderator
https://www.engine-codes.com/p2267.html
fio diesel dog
Jun 17, 2018 02:03 PM
thpd43
Apr 8, 2014 12:31 PM
TeckJohn
Mar 24, 2011 01:33 PM
92 BUCKBOARD
Dec 21, 2010 12:19 PM
EvilBowtie
6.7L Performance
27
Aug 2, 2010 06:09 PM
