48re No reverse , OD and even no torque lock with switch
Old Mar 22, 2021 | 07:13 PM
Whooptem59's Avatar
Default 48re No reverse , OD and even no torque lock with switch
I have an 04 Cummins. Trans is stock but I’ve done a bunch to truck and know it good. I’m just not good with trans. If I put my truck in R on a level ground it will go in reverse but any gain up is a no. After driving around for a month or two I new it had to be my rev servo. It’s almost like it’s not getting enough fluid but my first gear is money and is plenty strong. I bought a reverse servo nut havnt put in yet because I wanted to save money for Upgraded parts. Then comes the bs. Keep in mind I have a TC lock up switch. 33ohm resister. Still won’t lock my converter. My question is what should I buy or what do I need to get my transmission to go in reverse which I think is the reverse servo? And what do I need to do to get my overdrive and lock up back need help ASAP and I’ll take care of this truck I clean all the sensors. And these are the only two problems or three . Help I heard get a Governor pressure Solenoid. Transducer , Y’all help. I know so many things about engines on these Cummins but the 48re I’ve never played with.
Waj12v
10
Jun 19, 2014 06:27 PM
rollinblackcoal
Feb 9, 2013 09:33 PM
$2800 12valve
Jun 11, 2011 09:22 AM
bowtech
5.9L 12V Performance
11
Feb 17, 2010 11:43 PM
SmokinPiney
Apr 8, 2008 10:19 PM
