04.5-05 LLY Performance Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines Related To Performance And Longevity
What Gauges?
Old Jun 24, 2008 | 04:36 PM
Johnny Cetane's Avatar
Default What Gauges?
So what are the basic requirements for a Duramax? I'm planning on boost and EGT as usual.
Do I need a third like a FP gauge?
Fill me in boys.
Old Jun 24, 2008 | 04:45 PM
Fuel Press and possible Rail Pressure
Old Jun 24, 2008 | 05:23 PM
Diesel Dummy's Avatar
fuel or rail isnt a big concern until you really get into the fueling mods, but rail pressure would be the first, if you do a good lift pump they both will come hand in hand but i would say RP would be the most important. DD
Old Jun 25, 2008 | 08:37 AM
Do they make an electric gauge for rail pressure? I'd really like to not have fuel running inside my truck.
Old Jun 25, 2008 | 06:33 PM
2500HeavyDuty's Avatar
i dont think the fuel pressure gauge would work on a stock dmax since the cp3 draws its own fuel, theres no lift pump. I dont get a FP when my airdog is disconnected.
But if you were to add a lift pump then a fp gauge is needed.
I had 2 gauges for a while up until i installed my airdog.
Poost and pryo would be all you need.
i think they only make make electric rail pressure gauges, the pressure inside those things reach 27kpsi.
i dont think u want that kind of fuel funning in your cab.
Last edited by 2500HeavyDuty; Jun 25, 2008 at 06:33 PM. Reason: Automerged Doublepost
Old Jun 25, 2008 | 07:15 PM
yeah i forgot these new fangled ones have some crazy pressures.
Old Jun 26, 2008 | 09:06 AM
jdugie123's Avatar
it isn't bad the fuel never really gets into the cab i have disconnected my gauge before and had a towel just in case and didn't get anything coming out of it
Old Jun 26, 2008 | 04:16 PM
Were talkin about rail pressure 20-27kpsi.
Not fuel pressure 12psi.
Old Jun 27, 2008 | 08:50 AM
OK. Boost and pyro are on their way. I'll hold off on the rail pressure until I get more aggressive tuning.
Old Jun 27, 2008 | 10:38 AM
hold on....
You can get some of these for all kinds of stuff and add a FP gauge on the pillar when u instill a lift pump
https://www.dieselbombers.com/lb7-bo...tml#post119117
Last edited by 2500HeavyDuty; Jun 27, 2008 at 10:38 AM. Reason: Automerged Doublepost
