Overdrive help
Old May 25, 2020 | 02:26 PM
199612vc's Avatar
Default Overdrive help
1996 12v dropped out of overdrive one day and won't shift back in. I have replaced the break switch, tps, lockup and overdrive solenoid, make sure my batterys were clean and charged up holding a load. Tranny temp never runs over 140 degrees or slips in any gear shifts perfect locks up in and out no problem but won't even try overdrive. Sometimes if I am driving it when the tranny temp is cold under 120 degress and the drop the rpms below 1500rpm at 55mpg it will shift in and i have to very slowly bring it back up to speed or it shifts right out of overdrive. Is there a tranny temp sensor that can be faulty and causes it to kick out?
Old May 25, 2020 | 10:18 PM
ncovey's Avatar
I believe the temp sensor is in the solenoid pack if I remember correctly. Do you have access to a scanner to watch the pcm to see if it is calling for lock up?
Old May 26, 2020 | 01:44 AM
199612vc's Avatar
Yes, I do have a scan tool. I just pulled a code for governor pressure sensor circuit A and tps over volted.
Old May 26, 2020 | 10:50 PM
ncovey's Avatar
What is the pcm calling for when the torque convertor should be locking up?
abuchanan250
13
Sep 20, 2014 11:40 PM
dodgeramit10
Oct 22, 2013 05:44 PM
Cowboy92
May 30, 2013 09:49 AM
96cummins12v.
12
Apr 1, 2013 08:43 AM
lodal cummins
14
Apr 5, 2010 09:34 PM
