High coolant temp under load
Old Dec 28, 2019 | 01:49 PM
sinwagon's Avatar
Default High coolant temp under load
New radiator, fan, fan clutch, water pump and thermostat. Any hard pull with the rpm above 2300 rpm and the temp gauge climbs to about the 3/4 area of the gauge, I'm usually off the throttle by then and the temp comes down. Any ideas? 190k auto trans efilive
Old Dec 30, 2019 | 07:12 PM
Bigg Redd's Avatar
That sounds perfectly normal to me if youre towing heavy and going up a steep grade. You indicate "hard pull" but that's open to interpretation. Do you mean hard towing, or as in hauling some serious ***?? You indicate 3/4 area of the gauge.....what temp are you looking at? Auto or manual trans? Mods? A bit more info might be helpful.
Old Dec 31, 2019 | 02:21 PM
01trailerpuller's Avatar
With all your replacements the next step is an electric fan. They aren't expensive and they are easy to install.
Old Jan 4, 2020 | 10:52 AM
sinwagon's Avatar
It's any time the rpms stay steady above 2200 and not fast enough for an upshift. Loaded it does it faster but does it empty too. Stock engine components built automatic. Efilive tuning but I dont really like the tunes so might find a different tuner.
Old Jan 6, 2020 | 02:33 PM
Bigg Redd's Avatar
Is that radiator the same size as your old one, same dimensions, core size (thickness)? What is your speed at 2200 & 2300 RPMs? Whats your EGTs at that speed? Im thinking a big too much fuel, causing higher coolant temps and higher egts.
Old Mar 16, 2020 | 07:46 PM
sinwagon's Avatar
Radiator is same size just all aluminum instead of plastic tanks. was doing this before replacing radiator. according to the gauge i have the egts aren't extreme. is it possible that i got a bad/wrong rotation water pump? I do think it might be getting close to due for injectors as i have a weird startup miss every once in a while, also leaning to it just being a crap EFI live tune due to the guy that tuned it was more familiar with duramax and he wont answer calls to retune so i will have to find a different tune and try that.
Old Mar 18, 2020 | 11:53 AM
Bigg Redd's Avatar
Try going back to stock tune for a while and monitor engine parameters, to see what happens. your tune may be over fueling, causing your heating issues.
Old Mar 22, 2020 | 05:40 PM
sinwagon's Avatar
Changed the thermostat again on a whim must have gotten a bad one temp seems to be normal on an uphill pull now. i still want a different efi live tune though
Rattler
Apr 19, 2013 07:28 PM
Rufneckj09
8
Mar 8, 2013 07:57 AM
Crazytown
34
Nov 21, 2012 12:37 PM
Chevy355mark
Mar 2, 2011 10:32 PM
redwood logger
11
May 10, 2010 12:06 AM
