1994 7.3 worth the hassle?
Old Dec 14, 2019 | 11:27 AM
TylerJack's Avatar
Default 1994 7.3 worth the hassle?
I was given a truck with a 7.3 natural, the only caveat is I have to pay the back tags on it, roughly $800.00 bucks to get it up to date. Considering I do not know much about these motors, based on the following I would like to know what everyone thinks if its worth the hassle or not.
The motor has 325K on it and I did an SCA test of the coolant which showed little to no additives present. The coolant looks good visually and is the green coolant. I pressure tested the coolant system, but the results are not reliable. By that I mean it did leak down but I never had time to rule out that my adapter was sealed properly.
The return lines are leaking, the previous owner gave me the kit to fix that.
The power steering lines are leaking, they seem fairly cheap as long as the steering box and pump aren't leaking.
There is a trans leak, however I think that is a hose up front.
The truck does start easy, and runs okay. What is everyone's opinion on this? Wasting my time on this project or worth it?
Fleetguard test strip 1994 7.3
Old Apr 28, 2020 | 12:42 PM
Stumblefoot's Avatar
Jump on it! Those are minor repairs. the engine itself is worth more than $800 if the truck itself is beyond repair.
throttleup22
May 2, 2015 02:04 PM
Kmac45
14
May 14, 2014 06:21 PM
crowellalex
Chevy/GMC Duramax 01-04 LB7
Jun 2, 2013 08:23 PM
wildbill
Feb 27, 2010 10:58 PM
Herman
Feb 6, 2010 02:52 PM
