Lb7 duramax no start low rail pressure while cranking
Old Apr 16, 2019 | 10:59 AM
Logandoucet's Avatar
Default Lb7 duramax no start low rail pressure while cranking
Hey guys, New to the forum, so hopefully I post this in the proper page.
So I bought a 2001 duramax that wouldn't start for a great price, been trouble shooting for about a week and can't seem to figure out 100% what's wrong.
I started by installing a fast fuel pump with filters , replaced all the orings and fuel filter in the factory head, New batteries.
When I go to start it it will crank around 180-220 rpm but only build 500-600 psi of rail pressure. I did a return rate test ( with both banks and cp3 still hooked together) I get about 2oz of fuel return 70ml. If I unhook the cp3 and try it I get 25ml from both banks. I did this with the ign 1 Relay unhooked.
I can get it started with some spray, and it runs good. But if I command Max rail pressure at idle will only get about 6-7k psi. The balance rates had injector number 5 showing about 4.5-6 all the others were anything from 0.1-2.2. If I step on the gas I can get the rail pressure up to 23k and the desired Vs actually are always very close.
Even if I try to start the truck with the FPR unplugged it won't make any more than 500-600 psi. Also when I have the return from the CP3 off, hand priming the pump will steady push fuel thru the return of the cp3, I'm not sure if that's a sign of a failing cp3 or maybe it's normal.
I have not tested each injector bank individual since I'm not 100% sure what connections to unhook for that. But 25 ml from both banks seems OK? Average of 3ml per injector
Also when I get the truck running I get no codes at all. Hopefully you guys can give me some advice on what to check!
Thanks!
Old Jan 11, 2022 | 03:33 PM
Johnmazarek's Avatar
What did u fig out I am having same problem now
Old Feb 27, 2022 | 08:44 PM
wastefarmer's Avatar
Default Crank no start LB7
Did you figure yours out? Same problem 2003 lb7 GMC 2500hd. 107k miles.
Old Feb 27, 2022 | 10:41 PM
Default Lb7 no start
hard to believe ran like a top but had hot no start sometimes and after 4,000$ quotes on injectors and labor I did them my self threw Lincoln diesel hole kit was like 2,100 dollars with new lines and highly recommend with the rust I seen go in my injectors after dissembling I did not trust to pay 4,000 for someone do half *** job to do it again in few months it’s not hard just takes lil time and patience
Old Feb 27, 2022 | 10:44 PM
A lot of fuel returned back to tank couldn’t build enough rail pressure to start disconnected return line cranked for 15 sec had about 90-95 ml of fuel
Logandoucet
Apr 16, 2019 09:36 AM
DarrenKrueger
Feb 3, 2012 02:38 AM
thepunisher04chev
04.5-05 LLY Performance
17
Jan 19, 2011 06:17 PM
cumminsguy032
14
Oct 1, 2009 09:52 AM
OneBadBia
Oct 11, 2007 11:01 AM
