Time for a tranny?
Old Apr 15, 2019 | 01:08 PM
Chad_fen's Avatar
Default Time for a tranny?
I've done my research and can't find a definitive answer.
The 48re is shifting funny in my 05.
1-2 is slightly harsh most of the time
2-3 usually seems good.
3-4 seems to slip or rpm flare up during the shift. Doesn't happen every time. More so when I'm a bit heavier on the throttle or pulling my 4000lb trailer.
Happens in tow/haul as well
Just installed a borg Warner governor pressure solenoid and transducer.
Adjusted rear band while I was in there, front band was done not too long ago.
Time for a rebuild?
thanks in advance!
Old Nov 7, 2019 | 09:03 PM
Presmyk's Avatar
Try replacing the map sensor I had issue i tho8ght was a tranni issue but was a bad map sensor causing issues
tim12valve
9
Apr 21, 2015 05:51 PM
Trevlar11
Nov 16, 2014 01:59 PM
huntspud
Sep 22, 2014 05:14 PM
cuthbert97
8
Jul 13, 2012 11:10 AM
DD4x4Dually
Jun 9, 2012 02:22 AM
