Headlights
Old Mar 3, 2019 | 12:42 PM
thelt's Avatar
Default Headlights
The headlights on my '07 2500 and a lot of other regular Dodge trucks with this style headlight have the problem in the photos. I have tried polishing them with two separate polishing kits and the top of the headlight will not polish.
I ordered two brand new ones from Amazon. They both filled up with water the first time it rained and all the chrome inside turned black. Sent those back and got two new replacements. The left side condensates on the inside. Called them and they sent me another one. About a week later, before I could get the left side replaced. the right side condensates. Anybody have any idea why the condensation on the inside of the headlights? I have not installed the latest replacement. Anybody have any ideas on either case?
Last edited by thelt; Mar 3, 2019 at 12:44 PM. Reason: Trying to make the pictures smaller but to no avail. Sorry.
Old Mar 4, 2019 | 01:05 PM
PEKOKITTY's Avatar
It seems you are not alone. If you read the reviews on a lot of the web sites, a lot of people have the same problem. The seal around the lens is leaking. One reviewer over at Autozone, said he let the lights dry out after taking them back off and then put some clear sealant around the lens, and housing and that took care of it leaking. I do not know if this works though, as I never had to do it, but it might be worth a try. I also never had any luck trying to polish out clear plastic lenses.
Old Mar 5, 2019 | 08:00 AM
thelt's Avatar
Do you know of any photos of sealing the lense. I sealed around one of the headlights, but it still condensates across the top of the lens.
Old Mar 5, 2019 | 05:21 PM
Bigg Redd's Avatar
You cant really go wrong with genuine Mopar replacements. Theyre built better than aftermarkets. I had the same issues with my 06 Dodge ram. My originals got so bad it wouldn't pass safety inspection. Ordered aftermarkets and they collected water really well. Sent them back and tried another manufacturer, and left side leaked, the right side lens began "peeling" literally PEELING apart. Finally bit the bullet and got Mopar factory replacements. Still look new after 5 years....no leaks or condensation issues. Just food for thought...….
Old Mar 6, 2019 | 03:11 PM
11B/11C's Avatar
The lenses need to be sanded and sanded correctly. Stop sanding at 1000 grit and apply spray max 2k clear coat. Aftermarket housings are garbage and will have issues. The lenses on aftermarket housings will go to crap a lot faster then OEM.
Old Mar 6, 2019 | 03:19 PM
11B/11C's Avatar
these fog lights from my second gen used to be all hazy/yellow/cloudy, but after sanding them down, i can actually see through the lenses now.
Old Mar 6, 2019 | 04:28 PM
Bigg Redd's Avatar
That certainly works....but only for a while. It'll definitely buy you some time though.
Old Mar 6, 2019 | 07:30 PM
11B/11C's Avatar
that's why you spray them with spray max 2k. That protects the lenses from UV rays and keeps the lenses looking new a lot longer.
Old Mar 7, 2019 | 08:50 PM
Bigg Redd's Avatar
I'll have to look into that. Ive never heard of that.
Old Mar 11, 2019 | 01:20 PM
11B/11C's Avatar
It's a good clear coat that you need a respirator for because it's not just your average rattle can of clear coat.
carid
Diesel Bombers Sponsors
Mar 11, 2020 08:04 AM
carid
Jan 17, 2018 06:12 AM
usmcdiesel
Feb 21, 2011 01:30 PM
smokedout
Jul 12, 2010 08:03 PM
JS2TZU
Show And Tell
23
Mar 31, 2009 01:22 AM
