On the road spare parts
Old Feb 25, 2019 | 12:02 PM
sonnylynnvick75's Avatar
Default On the road spare parts
I tried looking for this but couldn't find it anywhere. I'm probably wording it wrong but what tools/parts do you recommend carrying in your truck for a quick fix on the side of the road?
Old Feb 25, 2019 | 04:12 PM
Bigg Redd's Avatar
Well that depends. You can never have enough tools to carry, but then your truck can only hold so many tools..... I carry a set of metric pivot wrenches 6mm to 20mm, set of metric 3/8" drive sockets, needle nose pliers, channel-loks , wire dykes, 1-short bladed screw driver, long bladed screw driver, the same in phillips screw drivers, spare fuel filter(s), zip-ties, small coil of bailing wire, spare serpentine belt, spare idler pulley, 1qt engine oil, 1qt trans fluid, 25' tow-strap, tire repair plugs, I have an air compressor and tank installed for PacBrake and air horns but it also serves to fix a flat, assorted fuses, high visibility emergency vest for sure, road flares, $200 bucks in small bills stashed in the cab, permanently mounted cb radio (in case your phone has no signal. This saved my *** more than once), jumper cables, radiator hose clamps and 3inch piece of stainless tubing to use as a spice for faulty radiator hose. I think that about does it for me. Oh, and a membership to an auto-club doesn't hurt, in case you need towing service, I have Triple A.
Its hard to prepare for the unknown, but some preparation is better than nothing. You cant go wrong with basic hand tools. Its a good start.
Old Feb 25, 2019 | 05:39 PM
9/10 I’ve got my dragbike trailer behind me loaded with tools. Im just interested in finding what everyone else carries with them, thanks for the input! I need to grab a piece of stainless for radiator repair.
Old Feb 25, 2019 | 07:52 PM
Bigg Redd's Avatar
Aluminum tube works well, if ya cant find stainless, FYI. BUT since that splice kit is only a roadside quick-fix, you can use any metal tube/ pipe. You wont be sorry b/c ya just never know.
Old Feb 26, 2019 | 08:48 AM
I like it. I was on my phone last night so I couldn't go into as much detail as I wanted. I usually carry:
A quart of rotella
A quart of ATF
A spare serpentine belt
Safety wire
Hose clamps
Fuel filter
Fuel overflow valve
Small nitrogen tank with regulator (in place of an air compressor
25' tow strap
4 way lug wrench
Fuses
Jumper cables
Tie downs
Various wrenches and screwdrivers
CB Radio
I need to pick up and add
High vis vest
Road flares
Tire plug kit
Roadflares
Idler pulley
and a some tubing.
I'm thinking about adding a spare lift pump to my kit as well.
Old Feb 26, 2019 | 06:27 PM
Bigg Redd's Avatar
Right on!!
Dieselhead1052
Feb 28, 2015 07:13 PM
articfox
Mar 20, 2012 09:01 PM
RollinCoal91
Dec 17, 2011 02:33 PM
az coil roller
For Sale
Sep 8, 2010 03:54 PM
RSWORDS
Price Quote - Request A Price
Oct 9, 2009 09:46 AM
