Dodge Diesel Tech Articles All Years of Cummins Tech Talk
Installation of Lukes Links
Old Jun 17, 2008 | 10:00 AM
Wyatt Earp's Avatar
Default Installation of Lukes Links
First Off:
I'll get some pictures but for now the write up. I finally got around to removing and installing the LL on the OEM track bar of my 2002 Dodge CTD 4x4. Well, I'll be the first to admit that his direction and instructions are very vague and somewhat lack luster but they do work.
Tools:
You will need,
* a Torque Wrench for 130 foot pounds
* a good set of sockets and extensions with a snipe bar
* a stud remover (joint puller) - Performance Tool, KD Tools, Snap On etc.
* a M14x1.5 tap and die if you damage threads like I did.
* chasis lube
* Bench Grinder (variable speed is not required)
* Bench Vise
* Thread File
* WD40 or equal for thread repairs
* Liquid Wrench
The process of removal:
1. Remove the bolt and flag nut from the connection at the left hand side of the track bar. You will need liquid wrench here!
2. Remove the pin from the top of the nut on the drivers side of the track bar.
3. Remove the Zerk Fitting from the underside of the track bar.
4. Install puller over this joint and slowly crank it down. Make sure it is in line. This will take a few tries to line up and get correct but you must be careful or you will damamge threads.
5. Once it comes out (it will with a loud pop) remove track bar from frame area and take into shop.
Stud Removal:
1. Clean up.
2. Fire up the grinder (use correct safety gear) and grind down the back side of the track bar as indicated on the instructions by Lukes Links.
3. Remove the full ball stud with a hammer or a press. Again, as indicated by Lukes Links.
4. Continue to grind until the cup from LL slides onto the track bar easily - do not force or cup will break.
5. Install parts as indicated by LL.
6. Clean up.
Installation:
1. Reinstall TB by hanging the stud in the frame at the drivers side. Make sure this is loose but not so that it will fall apart.
2. With a drift pin or equal pull the frame and track bar in unison to align the hole for the bolt and flag nut.
3. Torque all parts as indicated by Dodge - the left side bolt and flag nut shall be 130 foot pounds and the drivers side shall be 70 foot pounds. Be gentle but forceful with this operation.
4. Install CP in nut on drivers side and clean up.
Test Drive:
1. Slowly make sure everything is up to snuff and this can be done by finding a large enough area to run full circles with the truck. Listen for pops, grinds and or other funny feelings.
2. Drive is as per normal if everything checks out and recheck the 130 and 70 the next day.
Cheers.
Old Jun 17, 2008 | 02:40 PM
Whit's Avatar
Site Mascot
This is some good info Devon
looking forward to some pics there stud
this will surely help someone along the way
Old Jun 17, 2008 | 08:21 PM
Wyatt Earp's Avatar
No worries. In the past I had more than a few customers that complained about the instructions from the manufacturer so if this helps someone else then cool.
Sorry Kevin,
Camera didn't work and didn't the save the pictures.
Last edited by Wyatt Earp; Jun 17, 2008 at 08:21 PM. Reason: Automerged Doublepost
Old Jun 18, 2008 | 06:09 AM
91rangerturbo's Avatar
Did you notice a difference after the install? I have a set of these that i need to get around to installing. Thanks for the directions.
Old Jun 18, 2008 | 06:52 AM
Jazz's Avatar
Sorry Kevin,
No big deal just tear it apart and do it again
Old Jun 18, 2008 | 09:06 AM
Wyatt Earp's Avatar
Did I notice a difference - yes, the steering is much stiffer. This is in addition to the DSS which I have under there as well. I figure if you put all 5 lukes links on you would have one kick *** steering set up.
Yeah, no, sorry.
Last edited by Wyatt Earp; Jun 18, 2008 at 09:06 AM. Reason: Automerged Doublepost
Old Jun 19, 2008 | 06:46 AM
thanks for the input on this.
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
carid
Group Buy
Apr 8, 2015 06:11 AM
jrsavoie
Feb 6, 2015 09:44 PM
W350-4x4
Nov 12, 2014 09:35 AM
bustedknuckles
Oct 2, 2014 03:22 PM
