Show And Tell Got Photos or Videos of Your Diesel ? - Post Here and Tell Us About it , We Support Most Video Sites , Diesel Videos will Auto Embed .
just got off the rollers.... not real happy but not too sad....
Old Apr 15, 2007 | 07:12 PM
Benjamin's Avatar
Bombardier
Default just got off the rollers.... not real happy but not too sad....
just got off the rollers.... not real happy but not too sad....-new-dyno.jpg
the blue run was done back a couple of months ago in :q: stock :q: form.... todays is in red with the stuff in my sig..... i still think there's ALOT left in it as i still have the nitrous and the meth that wasn't used... still @ stock timing and with very minimal tuning done after all parts were installed..... i was running ~50psi didn't look too much @ the EGT's........ the more load that we put on the truck the more power it made.... this run was 358/727 SAE corrected with 65% load on the truck so by 2300 i was full spooled.... with the old setup i only had 35% load and was full spooled by 1900 or so.... i think i might try stepping down to a 12cm housing to see if i can get spoolup a bit quicker....... or i can stay with this 14 and use the bottle to spool it a lil' quicker...... anywho i figured i'd share....
Old Apr 15, 2007 | 07:57 PM
Benjamin's Avatar
Bombardier
mods please move to show and tell.....
Old Apr 15, 2007 | 08:13 PM
DazedandConfused's Avatar
What all is done to your trans? Is it the basic or what? Not bad numbers I dont think.
Old Apr 15, 2007 | 08:16 PM
Uncle Bubba's Avatar
As you wish.
Old Apr 15, 2007 | 09:03 PM
Benjamin's Avatar
Bombardier
from front to rear.....
Billet ATS SFI flexplate, tripple disc modified 15 blade stator ( really tight @ 1750 or so), :q: noisey :q: 47re front pump, billet input shaft, billet intermediate shaft, 48re forward clutch drum, MagHytech pan, Billet 1-2 shift lever, Daves valve body, and an aux. cooler with fan mounted under the cab..... Dave said it was overkill for my truck but i wanted to upgrade my tranny once and forget about it.... the only thing that i didn't get billet was my output shaft and that can be replaced without tranny removal.... but i think the stock U-joints will go before it does..... i think with a stock flexplate or a reinforced one and a single disc i would have a little higher number as that would be a big difference in rotating mass.... i just wanted to get a converter that would lock and stay locked and not slip.... and this one is it.....
Originally Posted by 99 cummins
As you wish.
thanx
Old Apr 15, 2007 | 09:07 PM
Hey if you dont mind PM me with what your setup cost.
Andy
Old Apr 15, 2007 | 09:25 PM
Benjamin's Avatar
Bombardier
Andy
pm sent....
Old Apr 15, 2007 | 10:10 PM
duramaxdavid's Avatar
THose numbers arent to awful.
Aug 31, 2015 12:00 PM
