94 12v Cummins Billowing white smoke Running aweful
Old Jan 14, 2019 | 09:06 AM
RickGoolsby's Avatar
Default 94 12v Cummins Billowing white smoke Running aweful
Hey guys relatively new here I just bought a 1994 12v Cummins slt 2wd with 109,xxx on it. Since I bought the truck (about 2 weeks ago) Ive put 3kgs in, ground down the fuel plate to a zero moved the afc housing full foreword. I went out this morning did a little fine tuning to the AFC (backed out the “smoke screw” about a turn and a half) trying to get a little more power, then let it warm up for about 30 mins then took the truck for a spin around the corner and gave it a little gas and heard a poof. Cloud of white smoke an when I give it any throttle it shakes horribly, could barely baby it home maybe 5mph and still billows white smoke when it is parked. Also when it’s parked it feels aweful very low idle when you touch the gas it kinda wants to die out but doesn’t. Check engine light isn’t on either. Any ideas? Thank you in advance!
Old Jan 17, 2019 | 09:02 PM
Crawler's Avatar
Check for any blown intercooler boots.
Double check your GSK. Based on your description I’d suspect the issue is there.
After that, put your afc as close to stock as possible.
Have you worked on a p-pump truck previously? Have you worked on diesels previously? Have you worked on a turbo charged vehicle previously? I’m not trying to be condescending. I just don’t know how basic or how detailed to be while helping you diagnose the issue.
RickGoolsby
11
Jan 28, 2019 11:52 PM
Momo12valve
Sep 27, 2015 06:21 PM
1993cummins
Oct 14, 2012 11:35 AM
chpmnsws6
May 30, 2012 11:51 PM
Budgreen
Nov 8, 2009 12:08 AM
