96 F-350 won't start unless plugged in in under 60 degrees
Old Oct 24, 2018 | 09:40 AM
hollsc's Avatar
Default 96 F-350 won't start unless plugged in in under 60 degrees
Had all the glow plugs replaced a few years back but even since the truck won't start unless its plugged in when temps drop to below 60 degrees. Only have 116K miles on it and it sits inside a warm garage all year. Had a relay replaced and that was not the solution and know the glow plugs aren't getting enough amps to warm up I have put off trying to pinpoint the fix as it does sit in the garage the majority of the time and just plug it in 20 minutes before I need it but just getting tired of that so wondering what all to check. Once it starts it runs fine and starts up fine too after its been run even if it sits outside in the cold for a few hours after running it around. Any ideas of things to check.
Old Oct 24, 2018 | 07:37 PM
joebob3093's Avatar
Moderator
i would replace the glow plugs and relay again. make sure you only use motorcraft or beru glow plugs.
Old Oct 29, 2018 | 09:11 AM
hollsc's Avatar
Did just that used Motorcraft plugs and replaced the relay and that seems to have fixed it. Thanks again
hardwired
8
Jan 23, 2015 04:30 PM
Alexgardner
Mar 25, 2014 10:14 AM
Eliminator1974
May 20, 2013 09:57 PM
053FPower
Mar 1, 2013 09:43 PM
powerstroke74
13
Feb 11, 2012 06:41 PM
