6.5L - lots of black smoke during acceleration
Old Sep 23, 2018 | 09:10 PM
Tahoe2DR's Avatar
Default 6.5L - lots of black smoke during acceleration
HI,
I have a 1999 6.5L with about 300K miles that puts out a lot of black smoke when I accelerate. I think it's something with the wastegate or EGR but looking for help to diagnose.
I got code P0236 (Turbocharger Boost Sensor A Circuit Range/Performance.) I replaced the Wastegate solenoid and cleaned the inside of EGR valve as best I could and the codes went away, but not the black smoke. I get the correct vacuum from the pump (the needle is steady at 25 in-Hg) and about 14/15 in the wastegate line, the needle fluctuates. Should it fluctuate? With the solenoid removed, should I be able to blow through it?
The wastegate actuator arm moves when the engine is off and is pulled up when the engine is idling. Is there more I can check? Is it possible to take the wastegate apart?
Previous Issues/History:
-When I bought the truck, it showed code P1653, would idle fine but rev up to redline if I tapped the gas pedal. I replaced the PMD and the run-away RPMs went away after 10 or 20 restarts.
-The injector pump was replaced by a previous owner. (I have the old pump if anyone wants it) Could the issue be injector timing?
-Could black smoke be leaking injectors?
Thanks for reading.
Old Feb 10, 2019 | 08:47 AM
racer55's Avatar
when the engine is idling safely attempt to pull the wastegate open against the force of the diaphragm,if you can easily overcome the actuator it is most likely faulty-it should take a good amount of effort against a finger or 2.
UC Kid
Oct 20, 2014 10:06 AM
elsbland
Sep 7, 2014 06:15 PM
Levis95
Oct 24, 2013 01:45 PM
petew
Jun 14, 2013 05:52 PM
g64870c
May 16, 2012 09:11 AM
