Oil in turbo at intake tube
Old Sep 16, 2018 | 03:45 PM
Cbizzness's Avatar
Default Oil in turbo at intake tube
I have a 1999 Ram 2500 5.9 and it doesn’t get driven often.... like once every 6 months. I’m starting to drive it daily again and I was changing the intake out and noticed oil in the turbo... I also get some blue smoke in the morning until I start driving which this would explain... I haven’t seen oil on this side of the turbo so I’m not sure what it would be... see pictures... my oil level is a little over full to which I’m not sure of... any input would be appreciated. Thank you!
Attached Thumbnails Oil in turbo at intake tube-549044ce-de99-430b-a402-eb46391ed17d.jpeg   Oil in turbo at intake tube-4308b02c-9e76-412c-a509-1c43688d85e6.jpeg
Old Sep 16, 2018 | 08:31 PM
Bigg Redd's Avatar
Well that's not good. Ya might wanna rebuild or replace your turbo. That's a tell tale sigh that your turbo is on its way out. Sometimes turbos can fail catastrophically without much warning, or they can give warning signs. Its best to heed the warning.
Old Sep 16, 2018 | 08:50 PM
Cbizzness's Avatar
I agree... don’t want to make matters worse... ordered a rebuild kit and just going to do it now. Didn’t know if it was a seal or if I needed a whole new turbo
Old Sep 16, 2018 | 08:57 PM
Bigg Redd's Avatar
Good man! You'll certainly find out when you take it apart. Just don't cut any corners. "If in doubt, throw it out"...and get something with a warranty.......if budget permits of course.
Old Sep 16, 2018 | 09:11 PM
Bigg Redd's Avatar
Oh yeah, you indicated that your oil level has increased. That's usually a sign that an injector(s) is failing and dumping fuel in the cylinder(s) and mixing with the oil in the crankcase. Also cause for concern. We call that "making oil"........ Definitely address that issue, as that can cost you a total rebuild.
Old Sep 16, 2018 | 09:21 PM
Cbizzness's Avatar
I am going to change the oil once my turbo is done, then drive it a little bit and check the oil level. Could be I did that but I changed the oil like 2 years ago, so I don’t want to jump to conclusions yet, but if I find it’s still making oil, I will immediately address the issue, which sucks because those are new injectors but I’ve experienced bad ones before right out of the box.
Old Sep 16, 2018 | 09:30 PM
Bigg Redd's Avatar
One more thing. Rising oil level could also be from a failed or failing headgasket in an area that is allowing coolant to leak down into the crankcase, check that your oil isn't milky, or settling at the bottom of the oil pan. water/coolant will settle a the bottom, raising the oil level effectively. I'll stop now before you go out and light your truck on fire......
Old Sep 16, 2018 | 10:58 PM
Cbizzness's Avatar
Haha it’s all good, I definitely appreciate the input. I know what these things are about and I know how it goes, but I just did the head gasket and did a block test and it passed that way, but doesnt eliminate a head gasket, there’s just no exhaust gas in the cooling system. I don’t think the head gasket is the problem, but then again, I guess I’ll find out. Thanks again!
Old Sep 17, 2018 | 02:55 PM
Bigg Redd's Avatar
Good Luck in your endeavor, and let us know how it goes.
Old Sep 24, 2018 | 10:14 AM
turbo2332's Avatar
your turbo might be perfectly fine if your oil is diluted with diesel fuel... thin oil will run right past the sealing rings.
1994cummims
May 9, 2014 05:03 PM
shovelhead shawn
Apr 1, 2012 04:13 PM
oil_burner
12
Apr 26, 2011 11:24 AM
rogerm311
Apr 1, 2011 03:14 PM
magram
9
Jan 23, 2010 06:06 PM
