Correct injectors
Old Aug 7, 2018 | 04:27 PM
Mr Bird's Avatar
Default Correct injectors
I'm trying to find two things.
A good but not over priced source for injectors for a 94 12 valve.
Second, I'm trying to return the truck to stock as close as possible. The truck has a 188/220 cam and a 62/65/15 turbo. The truck is used to haul things, but not pull much. It has a flatbed on the back. Under slight acceleration if the RPMs are not above 1500 to 2000 the EGT rises to 1100 to 1200 quickly . I don't know what the current injectors are I bought the truck as is and now I'm doing the head gasket and studs . My question is will stock injectors be okay .
The pyrometer is located before the turbo in the manifold. I don't know if this makes any difference
Old Aug 12, 2018 | 05:36 AM
JBearSVT's Avatar
Power Driven Diesel has a pretty good budget injector. The pyro is in the right place, you could have a boost leak someplace causing the EGTs. Stock injectors will be too small for that turbo, but that doesn't mean you can't use them you just won't make as much power. Do you know what- if any- fuel plate it has in the injection pump?
Old Aug 12, 2018 | 08:21 AM
Mr Bird's Avatar
It has a custom fuel plate. I pulled the injectors a few days ago, they are the old 370 injectors. It was hazy at idle I believe they have the wrong spray pattern and are too big. I'm looking at a industrial injection set with 80 or 100 hp. I just got the heat back and have to order the head gasket. I will look at pdd, thanks for the suggestion.
Number21
Jun 27, 2014 05:05 AM
jasoncooperpcola
Dec 22, 2012 03:20 PM
Al31031
Nov 10, 2011 03:05 AM
cumminscwby
5.9L 24V Performance
11
Oct 3, 2011 11:20 PM
farmboy01
13
Dec 2, 2010 04:59 AM
