No power rough idle
Old May 1, 2018 | 10:11 PM
Dkasza's Avatar
Default No power rough idle
Today i removed exhaust stack took my truck down to the gas station with just a straight pipe about 4 feet long off the turbo. Lost power and started idling rough. Occasionally it will run normal for a second or two then right back to no power. I can push the pedal to the floor and no response. Im at a loss. It ran fine today then after i removed the stack all hell broke loose. Now its useless... Cant drive it to work like this... Any help or ideas?
Old May 3, 2018 | 07:48 AM
chopforman's Avatar
tps is gone.throttle position sensor (TPS)
Old May 4, 2018 | 01:42 PM
Dkasza's Avatar
Default Codes associated with my issues
P0480
P0483
P2509
P2149.
​​​​​The only change i made to the truck was removomg the stack from just in front of the rear. Axle and the s pipe going through the bed. After this i drove tje truck. 1/4 mile and everything is crap now.
Why would removing a section of exhaust pipe cause all the problems.?
It is 5 inch pipe from turbo back no catalytic converter or muffler. Is there a sensor or ground i am missing somewhere?
