2006 Dodge Ram loosing power.....
Old Apr 11, 2018 | 07:31 PM
DZLROKET's Avatar
Default 2006 Dodge Ram loosing power.....
first: no codes have been set (other than the "crankshaft position sensor" code that has been happening for years with no degradation of eng. power)
So acceleration is normal up to the point when I further depress the throttle, then the eng. starts to bog down and and RPM's cease to rise. If I back off on the throttle "some" power returns and RPMs slowly increase???
I cleaned the air filter and ran my scan tool looking for any codes but to no effect. Help please!
Old Apr 13, 2018 | 01:51 PM
DZLROKET's Avatar
156 views and no replies ??????
Old Apr 14, 2018 | 08:19 AM
chopforman's Avatar
First time i would do is remove your smarty jr and go back to a stock truck program and see if changes anything.
It could be your TPS
Old Apr 16, 2018 | 01:19 PM
Bigg Redd's Avatar
Could also be weak fuel pump, clogged fuel filter. Check basics first.
