Does the Ecm need reflashed needed a tuner?
Old Feb 15, 2018 | 07:01 PM
MudTireDriving's Avatar
Default Does the Ecm need reflashed needed a tuner?
2007, 5.9, 6speed (g56), dually,4x4. Truck is deleted with 4” straight pipe off the turbo, cold air intake, running a edge juice w/attitude (will be used for gauges only). This is how I bought it, no engine codes. Is it safe to say that the ecm has some type of tune to get rid of any engine codes? If I go with either a EFI Live or smarty will I need the ecm reflashed by the dealer? Reason I’m asking is I have a recall (passenger air bag sensor or something) and it’s goin in next week. If I need it flashed I want to make sure they do it. Also, anyone know if the dealer will do it automatically or is this something they don’t do unless asked?
Old Feb 24, 2018 | 10:02 PM
cerberus60's Avatar
There is no deleting to do on a 5.9, it doesn't have all that garbage. Whether ti has a tune is something you will have to investigate but Smarty will get you a recovery flash that will set it to stock if needed.
