V2203 DI piston Shaving???
Old Jan 14, 2018 | 05:14 PM
yellow68gto's Avatar
Default V2203 DI piston Shaving???
I am doing a light rebuild on a V2203 DI.
Back story
motor had 1900 hours and looks to have gotten a little warm. Did a comp test and found #1@500 #2@220 #3@490 #4@500
Pulled the head and found a bad piston in #2 with a little aluminum on the wall. Pulled and stone honed and everything cleaned up nicely. The top and bowl of the piston are fine so I do not think it is fuel related. I had hoped it was a head gasket.
I have found a set of used low hour pistons in great shape from a good running take apart.
I am thinking of throwing the pistons in the lathe and taking some meat off the top to lower the comp. from 20.5:1 to something lower? not exactly sure how to calculate Compression but found a compression calc and looks like if i take .050/1.27mm off the top of the piston i should drop to about 18.5 ( i think)
I will first do this with the set of old pistons and document how much "Meat" there is by destroying the piston.
ken
Old Jan 14, 2018 | 06:11 PM
double post
Old Sep 18, 2018 | 11:22 AM
tomayr's Avatar
A common way of lowering your C/R is by doubling up on head gaskets. Shaving anything off the piston will leave you with a very unbalanced piston and most likely not enough room between the combustion and the first compression ring. The other benefit from doubling up on the head gaskets is it gives you a very nice safety barrier
fummins2008
5.9L 12V Performance
Dec 19, 2017 06:57 PM
outcast420
Aug 1, 2013 07:25 PM
corvetteguy
Nov 28, 2012 08:06 AM
pullincrazy88
Apr 10, 2012 12:11 PM
cumminspwr11
12
Dec 15, 2010 02:17 AM
