AB injectors in a non california engine
So i just bought this truck, guy says it wasn't running when he got it, two injectors had oil coming out of them, he says he found out it was a California engine, I really don't think it is, all other injectors he said were AA but he put AB's in. It smokes whitish bluish at startup or if you get on it from a light. Another injector bad or is it an issue of AB's in an engine that wasn't made for them?
Believe me, i know. Got the truck like that i'm pulling them as we speak. I've got some old injectors to test with that were good. ran it for a minute earlier, driver side manifold was 140 degrees at each port, driver side was 60 except for the second port from the front which showed 80 one of the two ab's was in that cylinder, i know it wasn't running on 4 or 5 so im guessing the temp difference is just from the one or two not firing, putting a new harness and switching out the ab's now, the AA's that were in the back two look fairly new
Replaced cps, finished injector and harness swap, no change. Hard to start. Had to step on skinny pedal to start it. Starts up rough. P1212 code this morning. Still puffing white. White smoke from oil cap when opened. Doesn’t have enough pressure to blow cap off when it’s resting on top. Could I still have a bad cylinder even though it doesn’t blow the cap off?
