Good single turbo upgrade for towing?
Old Nov 26, 2017 | 02:08 PM
01trailerpuller's Avatar
Default Good single turbo upgrade for towing?
I have a 2006 5.9 with a G56 manual. The truck is in the shop getting head work, head studs and new injectors. It looks like I will have about $1500 left over to play with. Looking for a single turbo good for a daily driver and towing a 35ft 5th wheel? I need a turbo that won't surge with a manual.
Old Nov 26, 2017 | 10:59 PM
chopforman's Avatar
Put a big stick cam and industrial injection Viper PhatShaft turbo.By add these two modes I really like the way it pulls my fifth-wheel it also lowed my EGT
Old Nov 26, 2017 | 11:14 PM
chopforman's Avatar
I have a 2003 2wd quad cab/auto(47re)
with the three gauge (tran egt boost)
Here are my upgrades
new rebuild motor(balance rings and pistons)
big stick stage 3 cam
Industrial injection phatshaft turbo Viper 63
new bosh stock performance injectors
spiral K/N cold air intake( changed out to a S&B)
AFE big horn intake
Tranny has a shift kit and the valve body drilled out plus a heavy duty toque convert
Old Nov 27, 2017 | 12:26 AM
11B/11C's Avatar
What do you have for tuning?
also do not waste your money on a cam.
Old Dec 2, 2017 | 07:50 AM
brdprey's Avatar
by adding that new cam, and the bigger turbo.
wouldnt you want to replace your pistons, head and a few other items that might not be able to with stand the new performance?
Old Dec 3, 2017 | 04:06 PM
11B/11C's Avatar
no, everything will be fine. The tranny on the other hand will need to be beefed up or an upgraded clutch if you have a manual.
oods are that the OP will be satisfied with custom tuning from a reputable tuner (if he doesn't have it already) and won't need to upgrade the turbo or other parts. Lots of people don't realize that you can get a better/cleaner running truck and more power getting custom tuning vs just throwing on a bigger turbo, injectors, cam, etc.
Old Dec 3, 2017 | 10:04 PM
There is no way I can put in a cam and turbo for under $1500. My wife will kill me if I spend any more than the money I have set aside for this work. Already put a solid flywheel and 600hp clutch and I'm running a edge CS. ALL I'M LOOKING FOR IS A TURBO UNDER $1500 THAT WON'T SURGE WHEN SHIFTING WHILE TOWING AND WILL WORK ON A DAILY DRIVER. My stock turbo has 200k on it. It has a little shaft play. My fueling outruns my turbo on any setting over 2 and my egts easily hit 1300÷. This isn't my first Cummins, just haven't kept up with what is on the market and I'm on a limited budget.
Old Dec 3, 2017 | 11:35 PM
11B/11C's Avatar
1300* is not hot, you can run all day and it's actually good for the engine to do that. It cleans out carbon build up in the cylinders. Your tuner is what's making your EGTs that temp, edge runs hot, they are not that great of a tuner. Your turbo should have some radial play, the oil pressure tightens that up. You don't want axial play in the turbo. What injectors and or CP3 does your truck have?
Old Dec 4, 2017 | 10:21 AM
1300 is where I have my edge defuelling. If not the sky is the limit. I try to keep it under 1100 for the most part. The play is past where it should be and is at the point where it is going to start leaking oil soon. The injectors are being upgraded to 50hp. Current fuel pump is stock with no signs of quitting soon. I just don't have the experience with matching a turbo to a manual. My last Cummins was an auto.
Old Dec 4, 2017 | 11:25 AM
1300+ for extended periods is extremely hard on your turbo. Aluminum can melt as low as 1220°. Manufactures state extreme risk of damage for 1250+ for extended periods.
