12 valve build. Need some direction???
Old Nov 21, 2017 | 07:35 PM
Andyhc1's Avatar
Default 12 valve build. Need some direction???
Alright fellas. I just bought a 1997 dodge 2500 12 valve. The guy i bought it from fire ringed the heads. Ported, polished, studded, T3 exhaust manifold, silver bullet 66mm turbo. Heres the kicker, no injector pump and no injectors.
Here's what i already own parts wise. 175hp p7100, afc mods only (about 2 years old). Brand new set of 191 delivery valves (not installed). 4gsk (not installed). 7x0.010 145* 100hp injectors brand new (not installed). New hx35 with wicked wheel and stock exhaust manifold.
I want to build the truck be somewhat a daily but also be able to pull and compete. Now with the parts i have readily available. What can i do and potential gains.
. Thanks in advance
Old Nov 22, 2017 | 11:54 AM
Andyhc1's Avatar
And if you need more info or something is worded wierd let me know. Ill do what i can
Old Dec 5, 2017 | 07:24 AM
wpg6.5's Avatar
you might beable to make 600 ish horse depending how good at tuning you are. id get the timing to 21 ish and start there. the injectors are a bit small for that but can push them and see what you get.
