np241dhd failure
Old Sep 22, 2017 | 09:50 PM
GMC 6BT's Avatar
Default np241dhd failure
Hello, I used the dodge np241dhd from my donor truck for my 6bt awap into a gmc and recently had a transfer case failure and had a question for anyone who is familiar with this tcase: the failure was the range fork wore out against the range collar, it may have been due to improper linkage adjustment causing constant tension on fork to collar. Now that i have the replacement parts i noticed that the new range collar is a rather loose fit on the range sleeve, there is a snapring but only holds it from sliding off shaft, the collar has more resistance to slip inside the fork with new wear pads than it does to spinning on the range collar which seems odd to me. all mating surfaces look in good shape. Hoping someone could verify if this is normal or not. Thanks.
Old Sep 30, 2017 | 03:23 PM
u2slow's Avatar
I can't say for sure... you could probably compare notes with other NP241 owners. The DHD isn't unique as far as how the shift fork/collar work.
