48re to nv5600 starter spacer required
Old Sep 14, 2017 | 05:55 PM
cwkoehler's Avatar
Default 48re to nv5600 starter spacer required
So I have removed my 48re from my 2005 ram 2500 and wanted to know if a starter spacer is required when installing the nv5600 with bell housong to the original mounting plate on the engine. The bolts for the engine adapter to nv5600 bell housing look to be aligned. Does anyone know if I will need a starter spacer or can this be mounted directly to the original mounting adapter for the engine to bell housing
Old Oct 22, 2017 | 09:31 PM
floridabrahmer's Avatar
Arrow
Im in the same boat. Just went to bolt starter up today and its to long, im thinking the spacer is the whats needed. did you get it figured out?
Old Oct 23, 2017 | 01:41 PM
cwkoehler's Avatar
Yes, a spacer was required.
SKU: V2151
Item #: V2151
Brand: Valair
Condition: New
