VE Pump Won't Idle.
Old Jun 9, 2008 | 12:40 AM
DieselfreakMI's Avatar
Default VE Pump Won't Idle.
Driving down to Ohio. getting off the highway with my foot off the throttle..engine was wanting to stall. I got it shut down at a gas station when I started it back up it wouldn't idle but runs smooth off idle... fuel filter was changed couple thousand miles ago. HELP
Old Jun 9, 2008 | 10:36 AM
LOGANSTANFORTH's Avatar
make sure the lift pump is holding prime and check the fuel filter again......
Old Jun 9, 2008 | 10:51 AM
I dont know anything about VE's - but how about rubber fuel lines Logan? This is a common problem on P-7100's.
Old Jun 9, 2008 | 11:26 AM
could be.....just use the KISS method.....
Old Jun 9, 2008 | 11:49 AM
I replaced the lift pump a couple months again not even 5 thousand miles on it...I replace the filter... I was told over time the springs in the throttle linkage gets stretched so I adjusted the idle and it seems to idle and go down the road fine. sounds like its idling where it was before I think...I dont have a tach.
I think its fixed
Old Jun 9, 2008 | 11:58 AM
2001shrtbedcummins's Avatar
ok sounds good
Old Jun 9, 2008 | 12:30 PM
Air leak somewhere?
Old Jun 9, 2008 | 12:44 PM
Im going to check the lines just in case
Old Jun 15, 2008 | 11:47 AM
Any progress?
Old Jun 18, 2008 | 11:42 AM
RSWORDS's Avatar
I think its fixed
A good rule of thumb on the VE's to get the idle close is turn it up untill th emirriors stop shakeing. Thats about 750 RPM... Always been close for me.
