Marine Diesels Discussion of Diesels Used in Marine Applications Boats Ect
Two Cummins 12-valves
Old Jul 27, 2017 | 02:23 PM
fitterski's Avatar
Default Two Cummins 12-valves
Greets, I just joined.
I have two low-time 5.9L 12-valves in need of some attention (ram:44966271 & firepump:45654340) and I'd like to clear the following questions off my list:
What is the cam lift on the 175hp Dodge Ram model and on the firepump 6BTA5.9-F1? I can't find this in the specs
The torque/hp power curve for each, again not found in the specs. For the firepump driver I especially need the hp & the rpm at peak torque as that's the regime where I want to chose a hydraulic pump for it.
Hundreds of different 4 and 6-holers use the Lucas CAV pump, so does my cat-426, but exactly which part of a Lucas CAV pump is specific for the engine it's used on?
I can't find any rebuild kits for the above injection pump with the springs in additiion to the seals and gaskets.
What advance degrees do the different timing letter marks represent. This engine seems to be timed for 2100rpm only and I might want o retard the timing a bit for more acceptable idling and starting.
Thanks for any hints
