FAN CLUTCH P043
Old Jun 28, 2017 | 08:57 PM
powers1089's Avatar
Default FAN CLUTCH P043
Running a '03 Dodge Ram 3500 5.9, fan clutch went out. When it happened it destroyed both plugs. I had to hard wire a new fan. It is still showing code T0483. Why? Any help would be greatly appreciated. TIA
Old Jun 29, 2017 | 11:12 AM
powers1089's Avatar
Subject should have been ; Fan Clutch P0483
Old Jun 30, 2017 | 09:26 PM
cerberus60's Avatar
Make sure you got the wires right on connections, then, check the continuity on the wires back to the ECU. If they are good it shorted the ECU portion of the fan controller, if not you have a bad wire or pin on the ECU connector. When I pulled the connector on mine the pin stayed in the connector, not good for circuit continuity.
Old Jul 2, 2017 | 03:25 PM
powers1089's Avatar
This is how it is currently wired. Thanks for the response & help
Got from Dodge dealership. Truck side<br/>Green<br/>Black<br/>orange<br/>white<br/>blue<br/>
Fan side <br/>Blue<br/>pink<br/>yellow<br/>green<br/>red
