'94 5.9 Cummins won't start unless I depress throttle
Old Jun 16, 2017 | 06:53 AM
av3fire's Avatar
Default '94 5.9 Cummins won't start unless I depress throttle
I have a '94 5.9 cummins that has just started to not start unless I depress the throttle.
I am running a cold air intake and 4" open exhaust.
other than that no real motor upgrades.
The motor has approx 300k and once started it runs very good
I am afraid this will lead to something bigger
thanx for your help
Old Jun 16, 2017 | 07:54 AM
thisguy65's Avatar
check idle screw
Old Jun 16, 2017 | 08:05 AM
av3fire's Avatar
Originally Posted by thisguy65
check idle screw
I should have maybe given more details that i just remembered:
when i say it wont start, i should have said it wont stay running.
it will start (fire) but only for a second or less...... then shuts off.
once it is running it does idle and run as it should
are you thinking i dont have the idle set high enough?
