Please help Can't figure it out
Old Jun 5, 2017 | 08:47 PM
milner57's Avatar
Default Please help Can't figure it out
So I went through and put a new in tank regulator, lift pump, injection pump, 50 over injectors and tubes also the apps. Ever since I have done this my truck hasn't ran right. At an idle the voltage jumps back and forth from about 9.5 to 13.5 also the crankshaft and camshaft are married but jump back and forth from around 750 to 250. That's all that I can find wrong under idle. While driving, the first minute or two it doesn't do anything just a little sliggish. After that around 30 the rpms start jumping a little (maybe 100rpm) then around 40 the Rpms jump worse and the truck starts bucking. I have noticed it does it worse when it's hot out and not as bad at night. It does seem like the longer you drive it does start to get a little better but not by much.
Old Jun 6, 2017 | 04:01 AM
gh0stman's Avatar
Are you running an in tank pump and a lift pump? What is your fuel pressure at?
Old Jun 6, 2017 | 10:18 AM
milner57's Avatar
Like 15
Old Jun 6, 2017 | 10:52 AM
gh0stman's Avatar
Have you checked for codes?
Old Jun 12, 2017 | 06:20 PM
milner57's Avatar
Only code I have gotten recently is 1693
Old Jun 12, 2017 | 06:29 PM
milner57's Avatar
Also just went through and cleaned the connections for the harness and put dielectric grease on them, cleaned my battery terminals and fixed the ones that had either battery corrosion or a loose connection and replaced the trans speed sensor
Old Jun 13, 2017 | 03:14 AM
gh0stman's Avatar
If you got 1693 there are more codes somewhere. That is the companion code that always comes up. try clearing it and see what happens.
P1693 codes (SOLO) - Dodge Cummins Diesel Forum
Old Jun 13, 2017 | 09:08 AM
milner57's Avatar
I checked codes about a week ago and that was the only one I was getting, I'll check again tonight though
Old Jun 13, 2017 | 11:38 PM
davidthomas's Avatar
You say APPS, I imagine you mean the TPS?? If so you did calibrate that with an ohms meter and the two pins off the ecm correct? Second. Check grounds. Make sure everything is getting a good ground, go along the harness and clean all your grounds. A bad connection can make a computer do some weird things
