Shade Tree , Pro-Mechanics & Fabrication Discussion of Fabrication of various products form your diesel as well as welders, Power Tools , Hand Tools , Shops, Garages , Lifts And More Including Tips and Tricks
Reared swap
Old May 3, 2017 | 02:02 PM
Bigbore94's Avatar
Default Reared swap
Gentleman,
I have a 1993 3/4 ton 4x4 than I lost the rearend in and my question is until I have time to rebuild it can I put a Dana 60 outta a 1986 w250 gas pickup in it until I can rebuild my 70?... I know anything is possible but other then ujoints and little stuff will it bolt in and work?... both are 3:54 ratio. Thank you in advance for your expertise
Wayne.
Old May 3, 2017 | 10:40 PM
u2slow's Avatar
I've switched my '90 Ramcharger from 9.25" to Dana 70, and now a Dana 60.
Axle tube is 3-1/8" instead of 3-1/2". Pinion on 60 is shorter, so watch the driveshaft. Good news is you can swap/borrow the 1410 yoke from the 70. Hubs & drums are different, but the brake shoes and hardware are the same.
