47RH the same between the v10 gas and Cummins 12v?
Old Apr 27, 2017 | 12:38 PM
thisguy65's Avatar
Default 47RH the same between the v10 gas and Cummins 12v?
Wanting to confirm that dodge used the exact same transmission between the v10 gas and cummins 12 valve.
Also how many electrical hooks up are there on the transmission? 2 (neutral and converter lock up?). Safety switch would be 2 pins and converter lock up would be 3 (power, ground, signal?)
When I go to look at it, I want to make sure that I'm getting a 47RH and not a RE.
Old Apr 27, 2017 | 03:15 PM
AmericanHotRodSolutions's Avatar
They are the same. The 2 pin does not have lockup, three pin is lockup. The most forward pin is ground signal for the OD, the center is 12V, the rear is ground signal to Lock up. You really want the 3 pin. For the 2 pin front is OD and back is 12V.
Kerry
Old Apr 27, 2017 | 03:53 PM
thisguy65's Avatar
Kerry
Kerry,
The governors are different (brass for diesel and steel for gas) and the torque converter.
My main concern is the valve body and line pressure front pump.
Old Apr 27, 2017 | 05:05 PM
Yes, the gas converter is different but can be swapped for a lower stall and the governor can be changed too. I would not turn down the V10 47RH as its all doable in a diesel. Easy tricks and mods to make it work in a diesel. Any trans guy can make it happen, if you brought it here we could make it work easily. These are getting hard to find, I buy all I can gas or diesel.
Kerry
Old Apr 27, 2017 | 08:50 PM
thisguy65's Avatar
Kerry, I sent you a PM. Thanks again
