Smoke switch issues
Old Apr 26, 2017 | 10:17 PM
Glen Walter's Avatar
Default Smoke switch issues
alrighty boys I'm kinda worried now. I got a 98.5 second gen but it's got a 2001 motor in it, but anyways I'm not an electrician but I tried to jerry rig up a smoke switch but it didn't work and now I'm worried since it's wired up something's not right. I got an eery feeling when I read a guys comment on a map sensor and he said it made his truck not get enough fuel. Instead of more like I wanted but anyway he said that it made his turbo only put out eight pounds but I think if it's only puttin out eight pounds of boost it would run right? Just need some relief or if not some help would be great I appreciate it I'm only sixteen and don't know how some of this stuff works.
Old May 13, 2017 | 12:50 PM
CJonesy99's Avatar
Default Bad idea
Get a new map sensor and pull that switch out. If you want to drive around and smoke people out you should just get a tuner or some injectors, messing with the map sensor can cause you some unwanted problems and before you know it your spending alot of money for parts and your truck isn't reliable anymore.
