For Sale: 1994 Built Tripple Turbo Cummins
Old Apr 21, 2017 | 10:21 PM
Murdoch32's Avatar
Default For Sale: 1994 Built Tripple Turbo Cummins
Selling my 1994 Built Triple Turbo12 valve. Ultimate built transmission out of Boise Idaho. 900-1000 horse with 90lbs boost. Roll cage, PCS Monitor, carbeau bucket seats, air dog 200, Cal tracks, 1-208-312-1580 $16,500 obo
1- New Storm block ( not a 53) main studs with stiffening plate, and machined for 14mm studs.
2- New Crankshaft (Balanced and cryoed)
3- Rods with HD bolts (shot peened, balanced, and cryoed)
4- Mahle pistons from hasiley's (bowls have been opened to lower comp.ratio, and fly cut for a Buddah power cam, balanced, total seal rings, 14.5:1 compression ratio.
5- HD push rods with common rail tappets, and aluminium tappet cover.
6- 12 valve head with new 60lbs springs intake and exhaust, titanium locks and retainers, new valves, seals. Intake machined off with port work on intake and exhaust. drilled and tapped for custom intake, 14 mm studs haisley fire ring in the deck.
7- New pump gear, cam gear, oil pump, and crank gear
Attached Thumbnails For Sale: 1994 Built Tripple Turbo Cummins-img_2952.jpg   For Sale: 1994 Built Tripple Turbo Cummins-img_2948.jpg   For Sale: 1994 Built Tripple Turbo Cummins-img_2939.jpg
Old Apr 23, 2017 | 05:20 PM
CJonesy99's Avatar
Do you have any videos of it running ?
Old Apr 23, 2017 | 05:38 PM
Murdoch32's Avatar
I tried but it says its to long. I can text it to ya.1-208-312-1580
Old Apr 23, 2017 | 06:06 PM
Hillbilly1's Avatar
Probably can post it on youtube and copy the link to this forum replies.
