Compound turbos... Primary turbine housing question for my application.
Old Apr 13, 2017 | 05:29 AM
customshop05's Avatar
Default Compound turbos... Primary turbine housing question for my application.
Hi y'all,
I have been reading a lot over the past couple years here and am taking my time to get this build right. My question comes as to which turbine housing on my primary turbo will be best, and where to get it if I need to change what I have. I will be running a HE351cw stock with a spring controlled wastegate secondary, with a S475 primary; It currently has the 1.32 T6 housing on it with the 96/88 turbine wheel. Will I be better off with the 1.32 housing or the 1.10 housing?
Motor specs
91.5 12 valve
Std. Bore and stroke
Fully component balanced engine to less than 1 gram
Hamilton 182/214 Cam
1.45" Hamilton tappets
Hamilton 135# Bee Hive Springs
Smith Bros, Rods
6x.013 VCO Bosch injectors
VE Pump-
THD fuel pin
Bosch 3800RPM trimmed Spring
M&H Timing Spacer
Standard dia. fuel Lines
Upgraded to 2nd gen fuel lift pump with 15psi spring
NV4500 Transmission
This will be going into a 1967 C10 (2wd) pickup that will weigh 4600lbs with a 240 lb driver.
Rear axle ratio 3.07 with a 30.5" tall tire.
Primary use is daily driver however it will be pulling a boat on a bi weekly basis, and occasionally loads up to 15k for short distances up to 70 miles through mild hills of southern WI.
Any help or suggestions here would be appreciated. Thank you in advance. If you need more info please ask.
