Dodge Diesel Tech Articles All Years of Cummins Tech Talk
Quad Cab Back Door Latch
Old Jun 6, 2008 | 01:03 PM
Marine's Avatar
Default Quad Cab Back Door Latch
My passenger side back door outside latch is giving up the ghost.
Has anyone had the same problem? When you pull it out, it doesn't grab until the very last 1/8" of latch travel. It feels like something in there is slowly bending over time.
I have not taken the door panel off yet to look.
Does anyone have a diagram of the door latch mecahnism in there so I have something to compare it too?
Any input would be appreciated.
Thanks!
Old Jun 7, 2008 | 10:23 AM
DB Admin's Avatar
Banned
REMOVAL
  1. Raise the window to the full up position.
  2. Remove the waterdam. Refer to Front Door panel.
  3. Disconnect the actuator rods.
  4. Remove the bolts. (Fig. 7)
  5. Disconnect the electrical connector and remove the latch.
INSTALLATION
  1. Connect the electrical connector and install the latch assembly.
  2. Install the bolts and tighten to 10 N.m (89 in.lbs) .
  3. Connect the actuator rods.
  4. Adjust the latch as needed.
  5. Install the waterdam.
ADJUSTMENTS
  1. Locate access hole and remove the mylar tape covering it. (Fig. 8)
  2. Insert a 5/32-inch hex-wrench through hole and into adjustment screw. Loosen screw.
  3. Operate outside handle several times to release any restriction because of mis-alignment.
  4. Tighten adjustment screw to 3 N.m (30 in.lbs) .
  5. Test handle for proper operation.
Diagrams Attached
Attached Thumbnails Quad Cab Back Door Latch-133391613.gif   Quad Cab Back Door Latch-133391552.gif
Old Jun 7, 2008 | 10:28 AM
Marine's Avatar
DM,
Thanks for that, but that sounds like the front door. The quad cab window doesn't move up or down, it opens from the side and pops out on the trailing edge of the door.
I didn't think there was any electrical in the quad cab door.
Thanks!
Old Jun 7, 2008 | 10:39 AM
DB Admin's Avatar
Banned
This is the Information i have under Rear Door Latch for 2nd Gen CTD's i seen the window down and ect and wonder4ed WTF my self but the adjustments and ect are correct
Old Jun 7, 2008 | 10:41 AM
DB Admin's Avatar
Banned
INSIDE HANDLE ACTUATOR
Heres the INSIDE HANDLE ACTUATOR Info
REMOVAL
  1. Remove the screw and remove the inside handle. (Fig. 5)
  2. Remove the door trim panel.
  3. Disconnect the latch actuator rod. (Fig. 6)
  4. Remove the nuts and remove the remote handle actuator.
INSTALLATION
  1. Install the remote handle actuator and install the nuts.
  2. Tighten the nuts to 10 N.m (89 in.lbs) .
  3. Connect the latch actuator rod.
  4. Install the door trim panel.
  5. Install the inside handle and install the bolt.
  6. Tighten the bolt to 9 N.m (80 in.lbs) .
Attached Thumbnails Quad Cab Back Door Latch-133391542.gif   Quad Cab Back Door Latch-133391543.gif
Old Jun 7, 2008 | 10:44 AM
Marine's Avatar
I will definitely have to do this when it stops raining. I hate not having a rear door on the passenger side.
Thanks DM!
Old Jun 7, 2008 | 10:54 AM
DB Admin's Avatar
Banned
EXTERIOR HANDLE
Removal
  1. Remove the front glass run channel. Refer to Window Track.
  2. Disconnect the latch actuator rod. (Fig. 2)
  3. Remove the nuts and remove the handle.
INSTALLATION
  1. Install the latch and install the nuts.
  2. Connect the latch actuator rod.
  3. Install the front glass run channel. Refer to Window Track.
Old Jun 15, 2008 | 11:50 AM
Did you get it fixed Mike?
Old Jun 16, 2008 | 10:46 AM
Marine's Avatar
I haven't had a chance to get it apart yet. Hopefully this week.
Old Jun 23, 2008 | 09:28 PM
Benjamin's Avatar
Bombardier
Hey Marine
did you get in there and find anything?
